fault codes?
414 Views 1 Reply 1 Participant Last post by  beelzedub1
just read the codes on my wifes mk4 1.8t agu code and got these codes on VCDS
00544 - maximum boost pressure exceeded 35-10 intermittent
00561 - mixture adaptation 14-00 adaptation limit (add) exceeded
00515 - camshaft position (hall) sensor (g40) 30-10 - open or short to plus - intermittent
had to fit a new turbo about 3 months ago and it has crazy surging almost like its hitting a rev limiter. if you back off the gas you can then drive it gently past the hesitation.
it had this problem when we bought this car about 4 years ago then on day the problem went, after looking at the fubar'ed turbo that came off i would say the boost was able to escape via multiple cracks in the exhaust housing so cured the over boost. now we have a new turbo genuine not cheap chinese one the problem is back and i dont want to break this one.
any ideas?
this week the car has started to hunt on idle so rescanned and got the bottom 2 codes, so guess its either the sensor breaking down or bad wiring again any ideas???
thanks Mike.
1 - 2 of 2 Posts
1 - 2 of 2 Posts
