I picked my car up today after having a new rear axle mounted as the last one was damaged and the nearside rear wheel was out of line.
Anyway in short i had adjusted the tracking so even with knackered axle it still went in a straight line with straight wheel, one axle was fine this meant wheel was way out. I've scanned the car with a cheap scanner and it says "steering angle"
if i redo the tracking should i be able to shift the code of does it require more work than this?
