1 - 4 of 4 Posts
Friday,04,February,2011,20:43:15:16275
VCDS Version: Release 10.6.3 (x64)
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Control Module Part Number: 1K2 909 144 F
Component and/or Version: EPS_ZFLS Kl.2 1301
Software Coding:
Work Shop Code: WSC 00000 000 00000
VCID: 2F671487C79B
2 Faults Found:
02546 - Steering Limit Stop
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Mileage: 6960 km
Temperature: 21.0°C
Voltage: 14.20 V
Voltage: 14.10 V
00778 - Steering Angle Sensor (G85)
000 - -
Freeze Frame
Friday,04,February,2011,20:44:46:16275
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.LBL
Control Module Part Number: 1K0 907 379 K
Component and/or Version: ESP FRONT MK60 0103
Software Coding: 0021121
Work Shop Code: WSC 01279 785 00200
VCID: 3A7135D30CD9
3 Faults Found:
01486 - System Function Test Activated
000 - -
00810 - Sensor 1/2 for Brake Pressure
01423 - Lateral Acceleration Sensor (G200)
This is on a VW MK5 04 PLATE 2.0 SDI
I bought this car and it has been messed around with e.g STEERING ANGLE SENSOR & SLIP RING. I have adjusted the steering angle sensor and its giving a reading
The problem with the car is that the power steering assist is not working, And the steering wheel on the dash is lighting up orange
Has any1 got any ideas how to sort these codes? I have an original vagcom lead
1 - 4 of 4 Posts
