I have these two codes
000924 - Relay for headlight cleaning system (J39) - sporadic 009 - open or short to ground - I don't have headlight washers though and no obvious other problems - is this likely just to be a fuse or relay issue and does J39 control other things
01064 - Terminal 58d - Interior dimming - sporadic 012 - electrical fault - no obvious issue so I am puzzled
I have tried to clear these codes with my Autel VAG405 scanner - it says codes erased, then when I subsequently read codes again they appear.
Advice appreciated.
