1 - 10 of 10 Posts
Hopefully will be getting some engine spacers soon [H]
Am i right in thinking that if i get some 15mm spacers..I can just lower the front end 15mm more and it would be like before the spacers (only lower lol)
Might be a silly question [:$]
Also, which ones are better to get...15mm or 25mm?
Proffitt
Lol Hamidi, i would love to go as low as yours but funds wont let me [cry]
I might need to remove the ARB as i get a bit of rubbing atm.
Is anyone running 25mm Engine spacers with a 3" Milltek Downpipe? I am a bit worried about clearance or is it just a case bending the heatshield out of the way?
iirc, if you bend the heat shiel then you're ok.
Where you get / getting you 25mm engine spacers from?
1 - 10 of 10 Posts
