These sensors are easy to replace paul, Just find the sensor which will be housed in the thermostat housing pulll off the multi plug,,, undo your expansion cap to release any pressure,, put cap back on, remove the sensor retainging clip and pull out sensor ( and make sure old rubber seal comes out with it)
*please note coolant will piss out at this point*
put new sensore with new rubber seal in re-fit retaning clip plug back on,,, start up car and check its not leaking,, remove expansion cap and top up with coolant
put heaters to hot middle air vents and about 3 0r 4 speed setting to bleed cooling system,
once air is hot in vents put expansion cap back on and wait for cooling fan to cut in...
erase code job done
Lee
erase code job done
Lee
