1 - 18 of 18 Posts
A4 Avant 2.0TFSI Quattro S-Line Special Edition
Can someone get a dump of their golf clocks (VDO FIS TDI)?
In vag tacho just click on read eeprom and PM me it obviously so its not on the public board.
Need to flash passat clocks to make them believe theyre golf clocks [Y]
Cheers mate
PM'd cheers Chris
Cheers Matt aswell, will probably come in handy!
Cheers fellas
So do you have to buy the software or cable? As when i click on download you can download it - so where can i get the cable - i have a vag com cable if that will work?
No you can't use vag com cable you have to get a proper vag tacho cable as the license is programmed into a chip on the cable.
ah i see. same as vag com then? although i got a ebay cable then paid the license on their site. where did you buy it from?
you have a PM olibb.
Thanks again Chris, looks like your dump worked fine!
I People I know very old this topic but, I have buy fullfis passat and I want to change to golf iv. Possible send eeprom for me? Tdi vdo fis Thanks
1 - 18 of 18 Posts
