1 - 2 of 2 Posts
My driver's door been intermittent for a while now not working at all.pass window 2x rears all ok.so replaced switch unit and motor.but still just clicking on motor (black plastic unit.)like a solenoid.read a thread that the wires can break up in door shut by hinges.so stripped door and untaped door loom that goes into multi plug behind bonnet release catch kick panel.only to find multi plug and door multi
plug are wet from sunroof leak.terminals on earth etc all green and corroded.have put a fine bead on clear silicone around sunroof seal for now until I can get right pipe to sleeve sunroof drains.but my question is can I remove multi plugs on door loom and solder wires direct.or do I need to find new multi plugs and connect wiring that way
1 - 2 of 2 Posts
