You've more than likely pulled the regulator clips off the window itself, as the window's frozen in position [
] I've done it myself.
Not too bad to fix though. Door card off, open up the rubber inspection holes, get the clips into position and re-tighten. However you will need to defrost the window so it'll drop down a bit into the correct position for re-tightening.
