double din
916 Views 6 Replies 4 Participants Last post by  Imagewerx
hi i just brought a one of these
http://b2b.eonon.com/details.aspx?pro_id=952&product_no=D2208
i know its budget but it looks ok and i have blu tooth so no more fines for phone use thing is it only comes with two l shaped peices of metal that i cant see where to fix so i think i need one of these
http://cgi.ebay.co.uk/CT24VW08-Facia-Plate-Volkswagen-Golf-MKIV-/170582065587?pt=UK_CarsParts_Vehicles_FasciaPlates_SM&hash=item27b77bc1b3
is this the case or do i need to do some cutting and welding
billy
1 - 7 of 7 Posts
sorry cant help. But, that looks quite nice considering. How much you pay for it?
I had an Eonon similar to this one and yes you will need the fascia plate although i warn you now if it is anything like mine its a pain to fit and requires some cutting behind the existing stereo and some slicing of the fascia itself.
You won't need the double DIN sleeve,just use the metal cage that sould come with it.
Chris.
P.S. Good luck getting the birdsnest of RCA cables in behind it[:mad:].
i payed 129 off bay its not bad really had it going on seat of car
i was gonna cut the back out of the vw plastic cage left behind
and it has no cage just the 2 l plates that screw to side but i cant find anywhere ti fit them to car
and i know what u mean about rcas was thinking about cutting some off
with my pioneer i had loads of rca's! i was tempteed to cut them off then realised i had just paid £30 for them!!!
But, if you remove the glovebox (6 torx screws) you can pull the wires down as there is a small cavity there.
The same applies to the panels in front of the drivers legs,remove them as well as you probably won't find enough room on one side for all of them.
Chris.
1 - 7 of 7 Posts
