Greetings, got a weird one for you all.. hopefully we can get to the bottom of this.
So at first when i got the car absolutely no interior light was working, doors we're not showing up on cluster display as open(absolutley none) even when turning on lights manually still nothing.
At first glance i thought heck, maybe it's the door switches in every door.
But before that i thought i'll get another Comfort Module same partnumber, and then lights are working just fine, manually and when opening doors too, trunk aswell.
Here comes the interesting part, opening any door right now, turns on the lights inside(so the door switches are working). BUT in the cluster i get nothing, only thing that it shows as open, if i open it, is the bonnet.
Even weirder now, the car randomly locks itself when opening the trunk, as in when i open the trunk the doors all close. (Tried key out of ignition, key in ignition at run position, engine on, still happened NOT everytime but it happens quite often)
WILL POST VCDS SCAN of 46, asap, but from what i remember there's a fault with my rear right door module, could it be the culprit of all this? especially the random locking when opening trunk>?Already got a working rear right module, for replacing just did not get around to do it yet. Should i try another comfort module first?
Regarding the cluster i'm 99% sure it's not it at fault, i had it in another car before and it worked fine.
TL DR, when opening doors interior lights come on, but cluster does not recognize doors as open.
