1 - 6 of 6 Posts
does anyone know the part number for the brass ring thing that holds the lock barrel in place? was changing the barrels over on mine as the remote stopped working but it has dropped inside the door and its fallen in the bit that you cant get it out of.
not sure of the part number, but i did this when i had the same problem, i managed to get it out with some wire and alot of wiggling.
so i cant buy that metal bit separately, guess i shall be getting the coat hanger out and try get it back that way. is it easy enough to get this back into place?
No you can't buy it seperately,if it's fallen out because you've broken something the whole lock carrier with a new ring is only about £15 inc. VAT.
Chris.
1 - 6 of 6 Posts
