1 - 4 of 4 Posts
Hi everyone, ive had a look through the search but nothing directly answered my question, so......
Ive got a mk4 110bhp 130k miles and im having big problems getting it to go in 5th, alot of the time I get 3rd instead. I was just wondering if this could be fixed or do I need new linkages? If so, how much is it likely to cost?
Thanks, Paul
Is it a 6speed box?
The gear linkages can be adjusted pretty easily.
If u google 'diesel geek 6speed' you should find some drawings on how it's re-adjusted.
Pretty easily done within 5-10mins, pop open bonnet, lock down s elector, undo the links, set the gearknob into position + lock, adjust linkages. job done.
That should be enough to fix it.
If you really want, u can try replacing the end links too with new ones, but normally adjusting them is enough.
the video on youtube for diesel geek shifter adjust is the best to follow
1 - 4 of 4 Posts
