1 - 3 of 3 Posts
It's the GALA setting you need to change. It's the feature that turns up the volume the higher the speed.
With the radio switched on, push the TP/Set buttom in for over 2 seconds to enter menu mode.
Use the 2 rocker switches to move thru the menu to GALA and a volume level is shown in the display. Rotate the volume control to change the Gala volume
After 30 seconds of inactivity, the settings will be stored.
HTH
1 - 3 of 3 Posts
