decat. worth doing?
3831 Views 26 Replies 11 Participants Last post by  danny_sims
wanting to decat my 130bhp tdi golf and was just wanting to know is it worth doing?
was thinking of getting a straight pipe and getting a garage to cut the car out and weld that one in place. I have read that i might get an engine light on though if i do this? is this true?
is it worh doing, will it effect mpg?
cheers
jake
1 - 20 of 27 Posts
this gets asked almost every day use the search button[Y]
you wont get an engine light and your turbo will spool up quicker[:cool:]
yeah your cat has a sensor on it and it will get a light on the dash once removed..but the best solution is rather than a straight pipe is puting a sports cat..
he has a diesel, not a petrol. no post cat lambda on diesels [;)]
I did a de-cat on my Bora pd130 a year ago after the exhaust snapped nearby. At low revs and light to medium throttle settings, no real difference. At higher revs and more pedal, noticeably faster. The only downside was the exhaust smell was more like the old taxi smell. Mine went through its MOT a week later with just a note made about the cat removed. No lights or warnings on the dash. ?50-70 well spent.
ooh man sorry didnt see that i was a diesel it should be fine then mate..
wicked cheers guys, il probs get a garage to weld a straight pipe in then. It wont effect fuel consumpsion will it? and ibe heard it will make it more smokey?
what are anyones thoughts on exhausts on a derv? i wouldnt mind one, not a loud one and a disceet one which dosent come out the back.. worth getting? any recommendations?
Generally I believe all Dervs should have an Exhaust.....
Firstly because it would be far too noisy and smelly without, but mainly to pass an MOT. Oh, and the fuel consumption would be dump without one haha
Might want to re-word your question [:p]
haha alright sorry about that, i mean't like a sports backbox. On my old car the exhaust pipe came unwelded from the backback.. sounded quite meaty, but kept on cutting out when stationairy so i wouldnt reccomend!
any info on any non standard exhausts?
I have a decat pipe sat at home and will be putting it on my PD130 when I have time.
Hi!
Yeah, its worth it.
The pull range will be a bit different after the decat.
When I wanted to sell my car, I've changed back everything to stock OEM.
Was the driving the car with decat + sport backbox, cold air feed, Egr blanked before.
After the changing back to OEM, the car felt totally different.
She had no power after 3k rpm.
So with the decat u will get some free breath for the turbo, and the car will pull a bit differently.
Worth a try.
If you dont want to spend a fortune on some sport cat or something like that, just get a straight pipe, and get a professional to weld it to your system, and cut the old cat.
You will pass the MOT, so its not a problem.
You wont get any engine lights, cause diesel systems do not have lambda sensors.
Older diesels don't have lambdas, newer diesels are very complex.
do it.
its worth it and will also go well with a remap.
Interesting to note that decat'ing doesn't cause an mot failure... Anyone know why that is?
the thing we found with decats is its a more noticable change going back to a cat than removing it, odd.
Lets open a new thread, so we can swap our knowledge about it.
My opinion is..
Who cares about it?
And No, i dont know the reason, why will it pass the mot, but when they've tested the car, the mechanic was asking, where do I fill up, cause the result was impressive.And yap .. without the cat, plus EGR disable.
do it.
x2
i'll pop down to a garage tomorrow and get a quote on getting a straight pipe welded in!
1 - 20 of 27 Posts
