1 - 12 of 12 Posts
i used an old credit card and some tar and glue remover on the left over stickey stuff,
card wont leave any marks on the paint but you might get very faint lines where they have been, little wizz over with a buffer will get them all off
did mine ages ago but when I took the badges off it looked like someone had allready tried to remove them so all of them had scratches allong the edges of each letter [N]
bit of a pointless comment tbh but just to let people no they COULD leave marks!
Bora looks 100% better [Y]
thanks pal, pity its got about 3 inch's of dirt atm
Funny enough i have debadged my golf today! [:D]
I basically used a hair dryer to heat the adhesive behind the badges...
Some fine string or dental floss to remove the letters
rubbed the adhesive that was left from the removed letters with my thumb to peel the adhesive back
and finally used hot water with some kitchen cleaner and a cloth to remove the marks that was left over [:)]
20/30 minutes job for my golf and GTI badge to be removed
Hope this helped
i took the badges off mine - used my thumb and heat to get the big bits off and then used......
*hides head*
oven cleaner sprayed it on...counted to 30 and wiped off and it was all gone? was amazing! polished the area after just incase
put the kettle on! pure boiling water over the badges, it softens up the glue and in a few minutes your be able to pull everything off, dont worry it doesnt damage the paint. for any stuborn bits of glue left over i used brake cleaner and it comes straight off, the only problem that you might have is paint fade from where your badges were,
1 - 12 of 12 Posts
