1 - 11 of 11 Posts
I have on dipped beam light on the LHS not working, as I was having the rear axle bushes done the dealer said the light not working was due to it being cracked and a replacement is £175. I, for the life of me cannot see a crack and all the rest of the lights are working. I was just going to replace the H7 bulb with another from Halfords. Is this suitable or do I need to pay for the whole light assembly? If I do need to replace the whole assembly are the generic replacement parts for £50 ok.
1999 Golf
1.6SE 8V petrol
Any advice is appreciated.
More than a little steep, that is a sheer drop. It was a VW dealership as they were the best people for the axle bushes and gave a fixed price for them which was good. Although they love the hard sell.
More than a little as they wanted to sting me for a lot more I am sure. I am just going to replce the bulb and see how that goes first. I will risk the 4.99 and also test the fuses like the other posters had suggested.
I would sort the light out yourself, If the light isn't cracked it's a new bulb and even if the light is cracked it may be ok if it isn't letting water in or throwing the beam pattern out, you can always try and source a secondhand headlight online or from a breaker yourself at leisure.
Don't forget to replace the headlight you got to remove the bumper and the dealer will bung the labour on with the price of the original light, they will probably bung new bulbs in too, plus the dreaded VAT and it's not looking too good.
Plus you get the satisfaction of doing the job properly and saving yourself dollar.
you dont need to remove the bumper to replace light bulbs bud
I never said you have to remove the bumper to replace the bulbs, you do however need to remove the bumper if you want to replace the headlight and that is supposed to be cracked [;)]
haha another case of quick scan reading [:$]
The light has a small chip taken off on the inside but hasn't pentrated the glass to the outside so there does not seem to be any condensation etc. Just replaced the bulb and it all seems fine. It was a little fiddly with all the clips etc and the battery being in the way but it is all good now. Thanks for all the advice everybody, it has made a lot of difference with me gettng the right stuff done and not being ripped off. Much appreciated.
1 - 11 of 11 Posts
