1 - 6 of 6 Posts
I have an 08 plate 1.9 TDi estate which has suffered a front end shunt, the airbags did not deploy & the rads are undamaged. However all of the warning lights on the dash are on and where the odometer should display "error" shows. The car starts &drives but these lights are distracting. How do I return the dash to its normal state?
Tony
You could try and clear all the fault codes using VCDS, that will erase them but if their is an actual fault it will light up again
1 - 6 of 6 Posts
