1 - 3 of 3 Posts
Don't know if this is coincidence or not but since fitting a HID kit to my 2001 AUM Golf sometimes on start up the wipers will sweep once even if the wiper stalk is not set to on. Also found out yesterday that if I "flash" someone he dash and CD/climate control displays illuminate.
Has anyone had this happen to them?
Any help/advise is appreciated.
Just a small part of the long list of problems I hear about on a regular basis from people who have fitted cheap aftermarket HID kits,I'm guessing that's the case here?
Check ALL wiring connections around where any work has been done,if everything is as it should be then take the HIDs out as the cheap ones cause VERY bad electrical interference whichh can also affect critical safety systems.
Chris.
1 - 3 of 3 Posts
