Hi all, i'm in a complete loss with this cruise control nonsense.
I have a 2001 VW bora 1.9tdi(AJM, 115PS)
Swapped out a wheel speed sensor today due to ABS light being on the dash(vcds comfirmed, rear left was broken)
Changed the sensor to a brand new one, cleared codes in vcds and abs light went away. Tested abs, works perfect(none of the wheels locked.)
I hoped this would fix my cruisecontrol but no, if i turn the switch on the stalk on it will show a green cruise control symbol, but no matter what i do(slide and hold slider, press or hold button on top of stalk) it will NOT hold speed once i let go of the throttle.
I checked the clutch and brake light switches thru vcds(group 3 on abs module i think?) Both clutch sensor and brake switch work fine. Tried some codes but to no avail.
Only strange thing is I have ASR on this car, but it has never worked. I have an asr button next to hazard button but pressing or holding it doesn't do anything. With lights on it says asr in red like everything else but doesnt turn yellow or anything. Car rips burnouts everywhere so asr doesn't work.
Checked wheel speed sensor values too; all are dead accurate and expected values. Car currently has no fault codes anywhere, checked all fuses and no fuses are burnt.
I have a vag-com cable and VCDS lite, so i'm able to do a bit of programming, i used to work as a car mechanic so i can do a lot of things myself.
I hope somebody has an answer to this! Hoping to get cruise control working before the weekend as i'm taking a big road trip to scotland.
