1 - 5 of 5 Posts
Hi all
Two quick questions for all you electrical guru's
First is it possible to remove cruise control from a crashed golf or bora and retro fit it and if so what exactly would I need?
Second I've electric mirrors not heated, how would I go about getting them heated?
Thanks in advance, Shane.
Discussion Starter · #2 ·
Can anyone help with this?? [help]
Think I saw somewhere that the heated mirrors are worked off the rear window heater switch is this true??
Cheers Shane.
I dont see why you woildnt be able to remove the cruise control, you can buy it as a retrofit, unless the retrofit isnt the same as OEM?
Thanks Jack,
I've been looking at the retro fit kits online and they come with a wiring harness im just wondering if I remove it from a wreak will I get this harness?
Reason im asking really is that theres a breakers yard near me and the guys that run it are sound I can pick up stuff at a great price.
Pickin up Bora lit vents this sat off them and already got aero wiper arms, a rear wiper motor, door seal and two wishbones to put poly bushes into.[:)]
1 - 5 of 5 Posts
