1 - 18 of 18 Posts
Hi folks,
As title says:
Can anyone tell me if its possible to fit cruise control to .:R32?
If yes, can you let me know what parts are required (part numbers if anyone knows[:D])?
I know there were few other topics regarding that, but couldn't find anything on .:R32
Thanks in advance for the info.
Regards,
s-t-m
Banned
defo is possible on a 32!
Replacement Indicator Stalk Switch with cruise control p/n: 1J0 953 513 01 C
Additional wiring loom for cruise control switch p/n: 1J0 971 425
Guys,thanks for so quick replies [Y]
Is there anything else I would need apart from the stalk and wiring loom?
Stan
Banned
yep! you need instuctions too dude - its kinda tricky
IIRC the 32 as with other v6 VWs are prewired ECU end
you will also need to enable cruise control using a VW 1551 tool or VAG COM
That kit you linked to is for a MK5.
Is it the part number that denotes it being for a MKV then? Which ever way I have and know of others who have had retro fit cruise fitted to our MKIV's for £150 all in from a dealer. If a dealer is ignorant to this deal then give VWCS a call and they should "educate" the said dealer
Hope that helps
The part number and price is for a MK5,there is no offer for a MK4 so you can't really advise somone to complain to VW about a non existent deal.
I bought the kit from ebay from fella called dsgwagen. £60 for stalk and wiring loom.
Thanks for all the reply guys, now must ring the stealers to see if they will fit it [H]
Well I'll simply put it down to luck then
1 - 18 of 18 Posts
