1 - 7 of 7 Posts
When I turn left at slow speed there is a creaking noise which seems to be from front right wheel.
Here's the video.
Had car on jackstands to flush the brake fluid and had a look around. Couldn't replicate the noise.
But I noticed the rubber seal on the tie rod end has cracked - could this be the cause?
Automotive tire Wood Tread Gear Rim
Either that or a top mount bearing has gone and the noise is the rubber mount rotating and rubbing against the metal. Spray some light lubricant around the top mount on that side, if the noise goes away then it's that.
Thanks both.
If replacing tie rod end, should I do both sides at same time? The left looks fine but I guess car will need wheel alignment anyway?
The suspension is only 2 years old. Should I remove the top bolt and then spray lubricant down? WD40 or does it need to be something special?
Vehicle Hood Automotive tire Car Motor vehicle
Ideally do both, but it's not necessary, so to speak. You'll need an alignment afterwards, so if it were my car I'd do both so the alignment can be done with fresh parts, and saves having to do another alignment if the other side fails soon after.
WD-40 is fine. No need to remove the bolt if there's enough space around the cap to spray into the gap (in that picture there's plenty of space if you have a straw on the can). Be liberal with spraying it so it actually goes around the rubber bush.
@ttg4l you were spot on, thanks.
I jacked up the front of the car, lifted the front sway bar a little, undid the screw and sprayed WD40.
Now all is quiet.
Tire Wheel Car Automotive tire Motor vehicle
I'll do the outer tie rod ends and tie rod assembly at some stage.
Now all is quiet.
Glad to hear you've found the source. It would mean ideally you'd get new top mounts and bearings at some point, but it's by no means urgent. I sprayed WD-40 on mine about 5 years ago and still haven't replaced them. I'll probably do it this year, the whole front end needs a refresh.
1 - 7 of 7 Posts
