I was on the way to Castle Combe this morning going over the severn bridge when a big STOP sign appeared on the dash with the sign check coolant. So I pulled over, turned the car off, had a quick check and turned the car back on. The car had little power even when dropping into a lower gear and the temperature shot to 130C so I pulled over and called the AA as I didn't want to risk driving it any further till I knew what was wrong.
The AA man came and the coolant level was fine, the fans worked fine and when idling and revving the engine at a stand still the temperature did not increase. He thought it may have just been a little problem that had sorted itself so he said he would follow me to junction 18 of the M4 and if the temperature increased to pull over. I got about 100 metres and the temperature shot straight back up again. So i ended up getting a tow back to my house. He reckons it could be the themorstat. Anyone got any ideas?
Not the best of starts to the day at all
