1 - 2 of 2 Posts
Is the clutch switch part of the pedal on an 05 gttdi as the cruise control doesn't work anymore it used to plugged it into vcds ran all the output tests and seen that the clutch pedal does change any values when pressed but the brake and the switch all change the values from 0's to 1's showing they are working so I'm guessing the switch in the clutch is gone is it a complete pedal job or is it a case that a switch unit can be changed instead?
1 - 2 of 2 Posts
