1 - 20 of 54 Posts
Hi guys and gals
I am just letting you know that at the moment we have a few ECS 5 speed stage 1 clutches that we are offering at a really really stupid price of ?275.00 + VAT
The kit includes the lightened 14lb steel flywheel and the upgrade kit.
Its even got the bolts and the alignment tools inside.
Sorry but there is no technician in there to do the job for you , but hey with that price , what else would you expect
Call now as we dont have many left and the others will be here in about 2-3 weeks
Sarah
Hi Mate
For the 6 speed ones I would reccomend either the Sachs one at ?450.90 + VAT and that one uses the OEM dual mass and comes with the clutch plate and the pressure plate
With that I would reccomend the release bearing too at approx ?49.00 + VAT
Then there is the Helix set up at ?800.00 + VAT
That comes with the single mass flywheel and the release bearing
The Helix one is a stronger one
Unfortunately there is not a cheaper one for the 6 speed [:(]
Sarah
Hi guys and gals
Sarah
are the above clutch mention will fit mk4 golf 1.8 turbo .....
What power can these handle? Would one of these be better than the popular g60 clutch and flywheel people choose to put in the 1.8T's ???
Hi
These are stronger than the Sachs G60 clutch set up
But with the G60 set up you can do the Helix ones that are stroner
This is for the 1.8T Golf`s but only 5 speed ones not a 6 speed
Sarah
Hi
Sarah
Excellent, how many do you have in stock and how long is the offer running for?
Hi
We have 3 of these in stock
They have sold so well we are trying to keep them at this price for a while
Hope that helps
Sarah
Hi Mate
Sarah
Hi Sarah,
Can you just confirm what you get for the ?800 Helix set up, Is that the friction plate, pressure plate, release bearing and single mass flywheel? Also is this a paddle type clutch?
Also how much is the single mass flywheel by itself and is this compatable with the Sachs clutch aswell? I'm assuming the Sachs one is not a paddle type clutch?
Sorry for all the questions, but the wife drives the car more than me and I don't want her moaning about it being hard to drive
Chris.
Hi Sarah,
Can you just confirm what you get for the ?800 Helix set up, Is that the friction plate, pressure plate, release bearing and single mass flywheel? Also is this a paddle type clutch? Yes that is correct , clutch plate , pressure plate , release bearing and single mass flywheel
Also how much is the single mass flywheel by itself and is this compatable with the Sachs clutch aswell? I'm assuming the Sachs one is not a paddle type clutch? I am afraid that the single mass flywheel will not fit the Sachs clutch kit
It is not a problem Chris as this is what I am here for
Chris.
The only down side to the Helix clutch is the noise that you get in neutral with the single mass flywheel.It is not THAT bad and we have sold many of these.Helix have got a tad more weight on to the SMF to get rid of a bit of the noise though.
Do not do paddle clutch if the Mrs is going to drive it , as there is no bite to the clutch pedal , it is on of off NO inbetween
The feel that you will get from the Sachs and the Helix is not that far off OEM too
Hope that helps
Sarah
Thanks Sarah,
So the Helix isn't a paddle then?
And what torque is it rated to?
Also could you give me a price for the lot, including fitting and VAT and then a price for just the delivery and VAT.
Hi
So the Helix isn't a paddle then? No it isnt , so the bite will feel better than paddle
And what torque is it rated to? 350 lb/ft ish
Also could you give me a price for the lot, including fitting and VAT and then a price for just the delivery and VAT. Delivered to your door ?931.34 all in or fitted ?1181.62 all in fitted
Hope that helps
Sarah
No problem at all
That is what I am here for , when I can get on
Busy at the mo , but this is the part of the job I enjoy
Any more questions please feel free to call us back
Sarah
clutch tbh is a lot lighter than before mainly down to it being new being single mass it seems to rev better and pulls loads better  too
1 - 20 of 54 Posts
