Right guys after finally getting round to completing this swap last week I though I would complete a write up to help anyone planning a future install. I have not put full details of how to complete each section bit by bit, I have assumed you can follow a Haynes manual, have some knowledge of car wiring and have the ability to wire in connectors (if you have completed a cruise control kit or something similar you should be fine). If you cannot do any of the above then don't bother attempting the install as you will be left with a car you won't be able to drive.<o
></o
<o
> </o
First things first you need to source all the parts:<o
></o
<o
> </o
Climatronic Airbox with all motors, sunlight sensor and loom attached<o
></o
<o
> </o
<o
></o
<o
> </o
Climatronic Control Panel<o
></o
<o
> </o
<o
></o
<o
> </o
Kufatec Loom (or make your own loom using the donor vehicle wiring)<o
></o
<o
> </o
<o
></o
<o
></o
<o
> </o
It is worth noting the Kufatec loom is designed to fit with the 17 & 12 pin airbox loom (the connector circled in red connects to the existing wiring on your car). There is another version of the climatronic airbox which has a 10 & 12 pin loom, another member on here Josh4949 made this install you can view his thread for wiring help:<o
></o
<o
> </o
http://uk-mkivs.net/forums/t/246654.aspx?PageIndex=1<o
></o
<o
> </o
Also get yourself a Haynes manual if you don't have one already this will help with removing the dash and old airbox.<o
></o
<o
> </o
Before you start any work the first thing needed is to get the air conditioning refrigerant removed from your existing system. Either ring a mobile air con specialist or go to visit one who will remove your old gas and then recharge your system after you have done the install.<o
></o
<o
> </o
DO NOT vent the gas to atmosphere yourself by undoing the T40 torx bolt on the air conditioning compressor (that's the one below the alternator). This is illegal and is punishable by a custodial sentence, not to mention the gas is released at -68oC and will freeze your fingers should you leave them there too long and they will drop off! Right that is the legalities out of the way onto the main bit.<o
></o
<o
> </o
The install:<o
></o
<o
> </o
You need to get from this:<o
></o
<o
> </o
<o
></o
<o
></o
<o
></o
<o
> </o
To this:<o
></o
<o
> </o
<o
></o
<o
> </o
If you have a Haynes manual just follow the procedures for removing the central facia panel. I am not going to type this all out as it is all in the manual.<o
></o
<o
> </o
The old airbox needs removing:<o
></o
<o
> </o
<o
></o
<o
> </o
Again follow the Haynes manual for removing the heater matrix this will state for none air conditioned cars only, but the process is identical for both (they just say that as they don't want you messing with the air con as it is dangerous). This will involve draining all the coolant out of your car, remember if you connect the battery back up don't start your engine.<o
></o
<o
> </o
Right next comes the wiring, the kufatec loom is fairly straightforward to follow I have labelled up the 10 wires that need connecting:<o
></o
<o
> </o
<o
></o
http://i591.photobucket.com/albums/ss355/sneydy/Image220.jpg<o
></o
<o
> </o
The wires connect as follows:<o
></o
<o
> </o
<o
>As mentioned the connector circled in red connects to the existing loom on the car.</o
<o
<o
<o
<o
<o
<o
<o
<o
<o
<o
<o
<o
<o
The install:<o
<o
<o
<o
To this:<o
<o
<o
<o
<o
<o
<o
<o
<o
<o
<o
Label No<o | Labelled<o | Source Connector<o | Destination<o |
1<o | 17 Pin Connector<o |
