1 - 4 of 4 Posts
Got a weird clicking noise coming from the right hand side dash around the Cluster/Speed Clock area. Often occurs when i start the car or as i begin to accelerate or reverse. Sounds like an electrical issue but not to sure.
The car is a GT TDI 110 on 51 plate if that helps.
Thanks.
oooo audi
mmm if it was the left hand side the most likly cause id the recirculation flap motor like mine but yours sounds a bit wierd check the relays under the lower trim panel touch them when the clicking is present maybe you can feel and vibrations in either of the relays
I have an issue with ticking from behind the dials. It happens when you fire the car up, the ticking starts and the rev counter needle does not kick in until the ticking stops.
It also starts ticking again when you switch off the ignition for around 10 seconds then stops.
I removed the lower relay cover and tested to see was it any relays but the noise is coming from higher up as if its in the instrument cluster.
Cheers.
1 - 4 of 4 Posts
