1 - 7 of 7 Posts
Pauper with big ideas
Planning on giving my EGR Valve and Inlet Manifold a good scrubbing this coming week, but before I start taking bits off I have a couple of questions, as the Haynes manual I have is (as always) a rough guide at best. For the record, I have an ASZ-engined Bora.
The manual mentions several O-Rings and Gaskets in connection with the two parts, but doesn't go into detail, so:
  • How many O-rings and gaskets are there?
  • I understand that at least one of the gaskets is metal. Is this true, and again, how many metal gaskets are there?
  • Can any of the o-rings and gaskets be re-used, or do they all need replacing? And if they need replacing, does anyone have part numbers?
Also, does anyone have any hints/tips/tricks for doing the job?
Thanks in advance for any info on the subject.
Manifold gasket i found the stealers kept it in stock.. or maybe i was just lucky..
the rest.. for the sake of a rubber o ring.. and probably the cost of the fuel getting to the other motor factors.. stealers is a good a place as any.
ASZ Inlet manifold PN is: 028 129 717 D
I have it sat in front of me ready to go for when i do the EGR delete [:)]
But i havent got any of the other seals as i shouldnt need them.. Due to deleting the EGR and blanking off the EGR pipe off.
I also intend on using this guide.. altho im sure there are others floating about in the How too and FAQ forum mate..
I used this guide about 7 months ago to clean my EGR valve,and it proved to be a very easy and thorough guide to understand and follow. I am going to look at doing the EGR and inlet manifold next weekend,and again I will be using this guide as a quick reference (just took me 3 hrs of searching to find it on here again! Cheers MarkyB!) How did you get on with cleaning yours mate?
On and off, it took me three days- though most of that was soaking the inlet manifold in diesel to soften the hard-baked crap. Actual work wise... Disassembly, active cleaning (i.e. scrubbing), and reassembly... probably about 12 hours. Though that's with a lot of general fannying around and double (triple) checking.
Im hoping for a 2 day turnaround.. day 1 morning.. getting if all off.. and soaking..
day 2 morning agitating it till its clean.. and on again..
but nothing ever goes to plan.. So i booked 3 days off [:|]
1 - 7 of 7 Posts
