1 - 20 of 20 Posts
Lots of people on here have had problems at some point with their rear wiper.
The water pipe is prone to popping off and in my case the metal pipe
inside the motor that the water shoots through corroded.
I just got back from the stealers as I had to order a new motor
they also mentioned a 'support' bracked 1J0955665H ?1.63
so I got one of those not knowing exactly where it went.
It appears it's to fix the problem of the pipe coming off
as it locks onto the pipe on the motor and the water pipe.
Here it is.. I would recommend getting one if you
haven't had a problem yet.
Ive had this problem for a while, just cant afford to sort it out, been driving around trying not to use the rear washer!
I havent a clue how to get at it and see what the exact problem is! It seems to be leaking in the c-pillar, when i try to squirt water, so i dont know what the problem is!
sdesailly,this is caused by the washer pipe popping off the connection,this was quite a common problem with mkiv Golfs when i worked at the dealers. You need to remove the pillar trim(carefully),and you will be able to see the problem. Possibly you will require a new connector,i would fit one if it were mine,plus,trim a very short piece of pipe off(the bit thats come off the connector),and re assemble. We found that the most common cause for this fault was owners not using suitable/enough screen wash solution,resulting in the joint freezing up during winter! Hope this helps mate? Paul.
Quote: posted by stokeballoon on 19/11/2004 06:02:00
Red card for Pope1!! White beaches, sun all day long, cant really see the attraction!!
Dave
Hey Dave, I wish it really was like that. Don't know when I last went to the beach believe it or not. Last night's snow in the W. Mids was a bit of a shock to the system though [:O].
Just to let you know, it's a pain in the *** trying to fit this part
in the washer pipe. The pipe is too thick!!
I've tried heating it up in boiling water and melting it with a lighter
but no joy. I think I'm going to have to use another piece of pipe
to bridge the two pieces.
I also bought this piece as my washer pipe had come off but seems pretty difficult to fit - for the time being I just reconnected the pipe and I have not refitted the panel trim in case the pipe comes off again in winter. If you manage to fit it, could you please post a picture to this thread? Ta.
Just to confirm I have just attempted to fit this part with no joy. I just refitted the washer pipe as I found it with a cable-tie to help prevent it popping off. Mine is quite a tight fit anyway so I am not too worried about this happening
1 - 20 of 20 Posts
