1 - 11 of 11 Posts
I have just purchased on ebay a nice set of gt tdi 150 seats of a 3 door model on a 53 plate.My car is a 4 door model with standard "airport" upholstery seats.My question is will the airbag connections be the same and will there be any issues with the 4 door runners fitting the 3 door seats into these runners,by the way my car is an 03 model
Pro tinkerer
The runners are the same, but your connectors may be different. Also some front seats you screw two nuts onto them, and some you screw two bolts into them. If the connectors are different you can cut them off your old seats and use them on your new ones. Make sure you disconnect your battery before you start, or you will get the airbag light on.
THIS shows you how to remove the front seats
The rears are alot easier, but if you can't work them out send me a pm and I will talk you through it.
Thanks for the replies so far v comforting as i am driving 170 miles next sunday to get them but well worth £100 and they are mint condition as the owner has had them out for 2 years because he track day races it
Why does everyone insist on cutting them off ??? [8o|]
Just use a small screwdriver, open the connector and push the wires out !!
Ash
TIP:
If your airbag connectors are different and you have no patience like me to get matching ones and connect them properly then do this for a bodge job:
1. cut the connector off old seat leaving a couple inches of wire coming out of it.
2. strip both sets of wires about an inch off each wire (Mine had 3 wires, others may be different)
3. connect wires using these (pretty sure everyone has a wiring set), http://www.autoconsumables.com/ekmps/shops/227sparts/images/electrical-crimp-connector-terminals-fully-insulated-butt-connector-red-3436-p.jpg
4. Tape them up to stop them snagging under the seat.
Job done.
This is probably pretty obvious to everyone but thaught I'd try and help [:)]
1 - 11 of 11 Posts
