1 - 10 of 10 Posts
Am just wondering if you can change the colour the clocks light up, from blue? if so, is it simple to do?
thanks
free +1, I wanna know this as well. I'm sure in a minute someone will tell us both to use the search function at the top of the page...
Some of the red is the colour in the foils, so you could possibly get different foils. And i believe some of the red is from smleds, so you would need to change them.
Chris,
Are they white surface mount l.e.d.'s or actually coloured ones?
Both,they're coloured surface mount LEDs.Not very difficult to change as long as you make a note of their polarity beore cutting them off with a pair of small wire cutters.Then unsolder the remains one side at a time,clean the excess solder off and solder the new one in place as quickly as possible.
Chris.
Do you need to change the resistor as well - I thought say a red SMD or a blue SMD would run with a different resistance as well??
They do run off SLIGHTLY different voltages Graeme,red normally quite low at under 3 volts and blue up to 4 volts in some cases.It might be possible to choose some at the lower end their range (some are only just over 3 volts) so you probably wouldn't see too much of a difference.They aren't old fashioned resistor driven though,there's a dedicated chip that controls all the warning lights and illumination so not very easy to change the voltage.
Chris.
I did this on a Polo 6n (MK3)..It was fun looking back at it now..But you need a steady hand and patience..I used THIS website which had a tutorial for the Polo and in regards of the LED's that are needed I got them from HERE
You need SMD LED's, I think the part no was PLCC-2 3528 & PLCC-2 90 degree SIDELED..
Overall it wasn't that bad just make sure you take loads of pics as each LED has to go on a certain way in regards of the notches there are on it..its a pretty cheap mod, I paid about £7-8 but it completely changed the look of the Polo..
Neal
1 - 10 of 10 Posts
