Remove the window before unbolting the carrier panel mate, wind them down about 1/4 until you can see the bolts in the two rubber holes on the window regulator panel.
Two screws to loosen slightly (either 10mm or t30) but be very careful as the clips are prone to snap, then the windows will tilt out quite easily.
I wouldn't use duct tape, it's much easier and safer to just remove the window.
You will need a M-8 XZN for the door lock module.
Good luck.
Good luck.
