1 - 20 of 24 Posts
trying to change the buld on my front headlights
and had to give up,sore hands, broke the new bulb
there has to be an easy way of doing it.
please someone enlighten me,coz i am well slightly intoxicated off
Quote: posted by MikeTDI on 18/04/2005 22:20:58
the only way to do it is to take the front bumper off. i know, sad innit!
Do you know how easy it is to revoe the bumper to change HL?
Any diagrams would sure be handy [:)]
Quote: posted by Carlos on 18/04/2005 23:05:14
Try getting a young attractive female to take your car and the new bulbs to the dealers. I'm sure the mechanics will be pleased to help. [;)]
Yeah i can picture it now. Short skirt, long boots and ............... [^]
No seriously, i need a guide. I tend to break things [:I]
dont take bumper off there aint no need just take the black plastic backin off. and on passenger side need remove 2 screws and remove plastic,the metal clip on holdin the bulb should push back and to he left,shouldnt have a problem unless someone bent the clips before, if still stuck just get a little mirror in the day so can see where the clip needs go,
Quote: posted by Mikedav on 18/04/2005 23:22:01
I didn't take the bumper off...its fiddly as hell but I did mine in about 20 minutes.
And yes our engine bays are identical
Did you have to loosen the HL fixtures? or remove any part of the engine?
no matey the only think have to take off is the back headlight cover which has metal clip holding it on, and battery side need take 2 screws out and remove plastic cover then the back plastic of the headlight,they are tricky if not done before jus remember the clip holdin bulb in goes back and to the left,
1. Remove panel marked with a headlight symbol - slides up and out. Unclip retainer bar things
2. Unplug electric thing in the back of the headlight
Retaining loop holding bulb straight is held by a little notch - push the ring 'down' towards your leg / into the headlight and lift slightly to unhook it (DON'T undo the screw, believe me)
3. Sidelight bulb can be 'wiggled out'
4. Main bulb can be pulled out, but fiddly
5. Reverse process, move to passenger side which takes 1/4 of the time as you have figured out how to do it. Only other trim I removed was a panel bit on the passenger side, as the battery was in the way
Quote: posted by MikeTDI on 19/04/2005 11:32:27
you guys must have tiny willys.
Shhhhhhh don't tell any one!![:I] Naa I was just so determined NOT to take off the bumpers. I will not be defeated! lol But s**t did I get my hands injured the first few times[:O]and in the cold its worst!
I found it fiddly enough changing a bulb with the headlight unit removed from the car!
As for as I'm concerned, removing the headlights is the best way to go. It is long winded at first, but after taking the bumper off to get at my angel eyes several times in the last few weeks, my mate and I can get the bumper and lights off and on within 30 minutes - and no scatched hands! lol
My headlamp bulb replacement is a quarterly event for me...and they both always go within a week of each other. I now do it in the dark, and my "hands" are quite large thankyouverymuch. I have it down to 5 minutes....no bumper removal. I just have to sacrifice some flesh to the gods of VW headlamps....
1 - 20 of 24 Posts
