1 - 4 of 4 Posts
Ok ... what if i fit normal buckets on subframes do i need to switch off the seat airbag??!?!? does it turn all the airbags off if i do..?
IIRC you will loose them if you fit "aftermarket" bucked seat's as they use harnesses .. i know on my old 306 you could bridge the connection with a resistor in the end of the plug but don't know if its the same with vags this allowed the circuit to continue so the others would go off in the event of a crash .. i found that out the hard way!
1 - 4 of 4 Posts
