1 - 20 of 20 Posts
Changed mine once already but have boiled at few times again and i now have pagid red pads on so could do with some better fluid... what do you guys reccomend?
i dont want the full silicone treatment as i dont want to flush the sytem.. also where can i buy it cheap online..
Took my car for a bashing the other day, after 5 mins i was experiancing brake fade and thought wtf?!? Couldnt be the brakes, tested my fluid and was showing a 4% +  moisture content,Obviously i boiled the water. Changed fluid , putting DOT 4 in and went a some country lane thrashing for the night, was fine. I mean i cant see you having problems with DOT 4 unless you do track days maybe? I still think it will withstand that.
You are joking arent you.... I boiled good quality dot 4 fluid the same day I changed it with 6 ... yep six high speed stops.
All the 4motion (1400KGS ) is 5 or six stops from 120-130 + and the
pedal willl hit the floor.... the brakes are grossly inadequate for any
serious driving...
From what I have investigated, your only option will be to user DOT 5.1 fluid which will increase your boiling point by 10 degress depending on the brand of fluid that your go for.
http://www.h-e-l.co.uk/HEL_Performance_Motorcycle_Brake_Lines_Brake_Doctor_FAQ.htm
I have also read that just having fresh DOT 4 in your pipes, will be just as good a DOT 5.1 so I don't know if it would make any difference in your circumstances.
Also, not sure if it will help with the boiling, but have you though of trying braided hoses ?
For fluids, this is what google throws up
http://www.proven-products.co.uk/products/performance_brake_fluid.htm
http://www.envyperformance.com/index.cfm?fuseaction=product.display&Product_ID=1460
http://www.hispecmotorsport.co.uk/brake_fluid.htm
http://www.3gbrakes.co.uk/fluid.htm
http://www.apracing.com/roadcar/brakefluid/data.asp?code=CP4510
Cheers Russel thats what i was looking for ... would be interested in what fluid other people are running and how they find it
Old School UkMkivs Member
I run a dot 5.1 fluid on my race bike and never had any problems with the fluid boiling / brake fade and thats with 40 minute stints on the track at race speeds with mega hard braking. Brakes even get hot enough to melt the copper grease on the back of the pads!
Highly recommended but has a downside that it needs changing once a year.
Used to get bad fade on my old Calibra, new dot 4 fluid cured that. As far as I know dot 5.1 is a bit ott for the road but may be what you need.
Mad! If you can boil dot 4 in a golf that easy i wonder why they put it in say super saloons, M3 , M5 etc. Bit of a hazard if you ask me.
i use motul rbf600. dot 4. boils at 590c. works well, used cheap stuff before, but this stuff is great. pedel feels lot more confident
Just about to use Motul RBF600 dot 4 my self in the R32, did a bit of reading up on the net and there seem to be 2 choices, the Motul 600 and Castrol SRF.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:eek:ffice:eek:ffice" /><o:p></o:p>
<o:p> </o:p>
The Castrol is ment to be the best but at ?40 a tin its way too expensive and your going to need 2 tins, the Motul is ?6.99 for 500ml and you need 3 bottles. The Motul seems to go down well with the Scooby and Lancer boys so im going to give it a try, im also having some braded lines made up to try improve feel a little more also.
cheers
matt
i think 1.5l was used when had pads changed. the sutf works gr8 on the golf, plenty of power for it 2 slow down and hasnt let me down yet
Russel nice one for these links really usefull... I am possibly doing
the Nurburgring soon so want to get my car right before i go...
I'm doing a trackday at Oulton Park, hence why I want to get my brakes sort.
I have also emailed Opie Oils, to see if they might be able to do a discounted price, to which they have replied they should be able to do 10% if we can generate 4 orders i.e. 12 bottles.
No not yet Russel.... had disaster after disaster with the car, Wife
has done the tyre and I have done a steering rod and a pair of
droplinks so i am waiting for all the parts to sort it out
I use ATE Super Blue as recommended by Rich at JBF and I can highly recommend it too, its ?15 a litre though [:|]
When you going to the Ring Andy? Might be interested [:)]
The way this months gone probably 2010........... No hopefully if I can
get everything staright it will be a late run out in september, I know
it may rain but I have so many things to do and the car needs alot of
attention that i am just struggling to fit it all in.
The sandwich bar we started is starting to ease on my schedule but up
untill last weekend i hadnt had a day off in 6 weeks
Stewart how have you found tyre wear at the ring? I know some people have meg problems but othere sdont (Golfgirl)
PS I will be going as my neighbour passed me over all his in car and on
bike DVD's and they were pretty damn awesome.... pinhole cameras[;)]
1 - 20 of 20 Posts
