Easy to do mate I find it easiest to undo the to rear bleed nipples and pump it all through then fill back up and bleed all 4 brakes starting from the 1 furthest away from master cylinder.
You must do it correctly to avoid problems after the fluid change, particularly getting air into the ABS system, read my previous post from the link below to give you an insight into some of the symptoms you might experience. good luck.
