1 - 12 of 12 Posts
hello , ive been on here before and havnt a clue how to fix/repair cars [negative]
anyway 2 days ago i went to go into second gear and bang the clutch pedal died
there was a few bits of plastic kicking about on the floor and thats it
the clutch pedal has no tension whatsoever , once its pushed downwards it will slam up against the floor and stay there ?
at first i was told its was probably just a small part needed for the pedal
but also ive been told it could be much worse !
its bora tdi se 150 thou on the clock
any advice taken thanks [:-*]
All Star
The clutch pedal is a common problem on the mkIVs.
Why dont you ring up a stealer, and ask for a price on a new set?
mine went the other week i was told a small plastic clip on the side that holds the cable snapped got it fixed for 30 pound
that is what im hoping mate was just wondering if anyone had a bigger problem when this has happened [Y]
Karlos103
Just get new pedal and the plastic " U " shaped clip ( ball socket )that holds the pedal to the clutch master cylinder rod (ball end ) ..very common .
Usually the metal tab on the pedal which stops the plastic clip pushing out the back breaks off ..bit of extra weld would of stopped this ...think the new pedals are modified to stop this .
If you can find the broken piece of metal you can always weld it back on ...but you still need to remove the pedal .
Karl
thanks ! its just trying to find someone decent to come and look at it
the last bloke that was here said it could cost 800-1000 he was talking about fly wheels clutch kits and stuff lol
i hope its that much ! think that guy was trying to rip me to be honest
im based in the north east county durham way
a place called houghton le spring [Y]
theres a couple of garages its getting the car there thats the problem ill give them a ring tommorow and sort a price out
would i not be able to go to my local autostock and get one ordered in there ?
1 - 12 of 12 Posts
