Unless you have your SKC then its a dealer job, if you have it then you can do the procedure with vagcom.
There is software available which reads your SKC but it uses a special cable and isn't widely available.
IMO its worth it to pay your local dealer around ?70+VAT to fit, code the immobiliser and both key fobs.
If the mileage barrier has been passed (100KM) on your new clusters then you are stuck with it as far as I know, also dealers aren't keen on fitting clusters with mileage.
My clocks were recoded by the seller before being sent to me so came as 0 mileage.
right then,im now confused.just came back from stealers after buying sharan rear emblem,says that the milage off the bora will be transfered to mine? is this the case?.luckily the bora has only done 8846 miles but would rather keep it as its supposed to be.any comments
