1 - 6 of 6 Posts
Hi Chaps,
Rear door lock module sometimes won't unlock.
I am on my third new module within 18 months.
Last one fitted two days ago and this morning failed to unlock from fob.
Would it be simply bad luck and worth getting a replacement module on warranty; or is it fairer to say that there is an underlying electrical issue?
Maybe a dodgy wire running into the door?
Thanks in advance
Baz
full scan will bring it up, but as said above check the rubber leading the loom into the offending door, and the bit that goes through the B-pillar. it is common as stated.
1 - 6 of 6 Posts
