1 - 5 of 5 Posts
Hi all , took the car out this morning and i could hear a low droan noise coming from the back of the car and on investigation i found the noise was coming from under the back seat Fuel Tank pump/sender.
When i push the part where the wiring loom goes into the sender hard the droan goes away like something is vibrating on the cars metalwork is this possible.
Hi mate. ive got a Golf GT Tdi 130 im getting the same problem. Just heard it a few days ago. Have you had any luck with finding a fix or do we need new fuel pumps?
ive just located the part on ebay. The actual fuel pump is a vacuum pump and is located under the bonnet.
This part in question, under the rear bench, is the sender unit and is relatively cheap. £25 ish.
Thats as far as i have got. Keep me posted if you find out anything more.
1 - 5 of 5 Posts
