My boot lock has gone pear shaped and now wont let me in, noticed a few days ago the boot open light on the dashboard kept coming up so I had to keep getting out to slam it shut.
Also noticed water dripping from the lock mechanism whenever I opened the tailgate after using the rear washer.
Going to go out now and have a go at opening the boot using imagewerks guide from above, cheers fella.
Update,
Followed the explanation by imagewerx of how to get the hatchback open, worked exactly as described, you are a diamond fella, found the washer pipe half hanging off and the lock has been coated in screenwash, the lock didn't want to unlock.
Sprayed loads of WD40 into everything and closed the latch using a screwdriver a few times to get it to pop, now works a treat and washer pipe firmly attached so hopefully a dry hatch, have left the inside hatch trim off so I can grease it all up tomorrow to let it dry out.
Only thing I have now noticed is that the tailgate warning light on the dash is glowing faintly when the hatch is shut, I have checked with VAG-com and when shut it says it is closed, I can only assume it's the switch drying out, unless of course it's crackered.
