Status
Not open for further replies.
1 - 8 of 8 Posts
hi all
i have recently purchased my 3 mk4 golf and have an issue with a boost leak, does anyone have any ideas of how i can make a home made device to locate the leak
cheers
does this way find every boost leak, its starting to do my head in, but if it works then i will fabricate some thing at work
cheers for your input guys
so in your pic where do you put the pipe? i made one from a bean can and put it on the turbo inlet pipe pumped it up and heard quite a loud hissing sounded like it was coming from the block itself like a crankcase breather or something so just gave up.
Guttersnipe
You do need to block off the crankcase breather at the hockey-puck. I also block off the small hoses coming off the throttle body and test them separately
1 - 8 of 8 Posts
Status
