Hey
I've searched this forum many times but have still to find an exact answer to my question:
I have a none-DBW 1.8T. I recently got it revo'd and as much i like the upgrade, i was wondering whether its possible to up the boost more?
Anyone got experience of this on my type of engine?
Steve
N75J or H valve
MBC
K03s turbo
turbo back exhaust
in addition to increase power
bigger intercooler
samco intake pipe
depends where you want to stop.
The best place to start would be the N75 valve. You get them from VAG. Either may work, either may not. Suck it and see really.
the reason i say use the actuator is that my k03s/jabba car is now boosting at 1.6bar instead of the 1.4bar it was set up to run at,the boost went up after fitting a new maf. so i spoke to mike at jabba and he said wind the actuator in 4 turns and this will bring the boost down.do you think the manual boost controller would be better?
If you are trying to increase the boost by a few psi i would say yes for the simple fact that a boost controller is more controlable than winding out the actuator.
Starry in your case where your car was mapped for a certain psi and you needed to reduce the boost you were right to wind in the actuator because an mbc is only good for increaseing the boost when used with the N75.
Now if you were removing the N75 altogether it would be a different story[:D]
well acording to my Jabba rolling road session 239 bhp 263lbs ft, either that or my brand new boost gauge is poo!!
Does it make any difference where the gauge is plumbed to? I split the pipe with a t piece from the metal pipe to the dump valve acroos the top of the engine.
Can't remember I will check it at lunchtime, It was only ?40 off ebay but it lit up same blue as my clocks.
I'm sure Mick from Jabba said, when the car was in, it was only set to 15psi, my turbo's actuator was sticking at the time though. Now it isn't(after I got a replacement turbo to!)
jubbly, i have pretty much the same set up as you and put out the same power but that was running 1.4bar of boost which is a lot more than your running if you gauge is correct, which i dont think it can be. mike at jabba told me 1.4/1.5bar is max. but not sure what that is in psi.
Quote: posted by Mo on 24/03/2005 08:21:59
yeah the positioning of your t-piece should be ok.239 bhp with only 1 bar seems odd though.
What guague you got there ?
Almost forgot about this the gauge is a "stein" means nothing to me at all.[:(]
Wind up the boost too much without lowering the compression ratio of the engine and you`ll finish up with a nice hole in the side of your engine block and a repair bill to match.Most high boost tuners use thicker head gaskets made from steel to achieve this safely.
