1 - 5 of 5 Posts
Hi all, i'll have a boost gauge in a few days, thanks Santa [Y], just need some help so it makes fitting it easy as i have no idea [*-)]. Where do i put the T peice to run the vac pipe, how much vac pipe should i buy and whats the easiest route into the cabin, any pics or advice would be great. Thanks and hope everyone has a great Christmas, Dom
easiest route I found was through the grommet behind the scuttle panel on the drivers side then route it through the fuse box into the cabin.
I tee'ed in using the vac hose from inlet manifold to diverter valve
1 - 5 of 5 Posts
