1 - 20 of 56 Posts
What setups are you running front and rear? Please post pics.
I am considering a big brake kit, and at the minute my heart is saying ECS Version 2 up front and Version 1 at the back, i love the red porsche claipers and drilled/slotted discs. But my head is saying R32 front and back with a possible disc upgrade
. The main factor is the price, the full ECS kit is about ?500 more than i was planning to fork out, considering that by the summer i will still only be at 140 - 150bhp so i don't need mamouth stopping power.
Any help much appreciated[Y]
Have a little look in the "brakes" section.
You should find a few threads about the different set-ups some of the members have.
i have looked and searched for specifics, but most, if not all the topics:
1. the pics have been removed
2. discuss front brakes only
3. threads are dated 2004 - 2005
I have your ideal setup and can vouch for its effectiveness even after extreme abuse, but I sense that the R32 kit will be more than up to the job for your requirements and wallet. [:)] With the ECS kit you have to budget for replacement discs and these are a lot more than R32 ones too.
Cheers dude, are you running the ECS rears? I can afford the fronts ok, but the rears push it a bit over the top and i think it would look silly having big fronts and tiny rears. Did you get them from ECS or through a source in the UK?
I have the 2v2's and the Stage 2R vented 308mm rears. I got them from Richard @ www.jbrperformance.co.uk back in 2004.
WOW! you must only have to breathe on the pedal to be able to stop[:O] Do you have any pics of the wheel area?
If i go for Stage 2 up front and Stage 1 in the rear the price is good. Can the stage 1 be fitted to the rear? there is a rear specific stage 1 but id rather have the larger calipers back there.
LOL yep I have RichardW's and Tabs' teethmarks in my dashboard to prove it[:D]
Recently put some pictures in this thread
There are two rear conversions, for solid 232mm x 9mm discs like yours, and for the vented 256mm x 22mm discs like mine. It is possible to upgrade your rear brakes to the vented - again its a question of "is it necessary?" Both are 308mm diameter which is a lot bigger than your current front discs! Both make use of the current caliper and mount it further away from the hub. Details on www.ecstuning.com - for the vented discs look at the 337 Edition or R32 sections.
His is actually a 100pd thats listed because there isn't a 100pd highline tag for the side, so it will be the 280s, not sure if its an issue with the ECS brakes though as they come with a complete fitting kit for all cars I assume (or did I read somewhere that the hub on the lower engines were an all in one unit with the carriers?)
does look that way.... but with yours being a run out model, perhaps it has the 288mm brakes, best way to check is to look how the caliper carrier joins to the hub.
Just had a look through your golddigger thread, top job you have done there, mate[Y]
Love the black grill, thinking of this myself. Where did you get it from and how much was it?
John
Well, i had the whel off and i think they are 280mm[:(], i couldn't get a flat measurement, but with the curve of the hub it was 290, so i guess that an allowance of 10mm would be closer than 2mm. I have part numbers if anyone can verify the size
1J0698151G
1J0615301E
I think top is Disc and the bottom pad but not sure
EDITED for picci-tors, i guess as the cliper looks to be part of the hub, new hubs will be required.
Thats a shame [:(]
If you do decide to change the lot, I have a set of calipers sat in the garage, but no carriers.
It seems a strange idea tto build them into the hub[:S]
1 - 20 of 56 Posts
