1 - 7 of 7 Posts
hi
i recently bought an active fli sub, when i connect it up
my amp which powers the front speakers turns red and stops working when i put the volume up. (both amp and active sub work at low volume)
the sub works all the time at any volume
if i turn down the power on the sub to low, my amp which powers my front speakers starts working at high volume
any ideas plz
thick power lead is coming from the battery to the boot, then into a splitter box, one in four out
ground is running from each amp into the body at either sides behind the lights
It has to be a bad connection,how is the thick power cable connected to the battery anf fuse and how is the earth cable connected? I.e. what sort of connector,is it pre-crimped or DIYed and is it to good clean metal?
Chris.
where could it be
also when it stops working if i open and close the rear passaenger door it starts working for a bit
it is grounded to good clean metal
the ground cables are crimped
1 - 7 of 7 Posts
