1 - 20 of 37 Posts
Engine is now running 83mm 8.5:1 JE pistons, forged rods, ported largeport head, Supertech valves, PE1820 turbo, 3" DP (Dans), Dual Plenum intake manifold, oil cooler, 525cc/3bar injectors and RS4 MAF.
Runs without ABS now and aircon system has been removed. - mucho weight reduction.
Mapped Weds with the following results:-
http://badger-5.com/bin/Dyno/bill-ibiza-1900PE-small.jpg
410bhp, 513nm torque [:D]
Many thanks to Mike, Elton and the guys 'n galls at Jabba. Top job as usual.
Cars performance scarey at the moment.. and on the way home last night from peter bog horror, 120mph wheel spin in 4th gear was entertaining. [:O]
Spool up and response is superb.. much better than hoped for. Less lag than before, but a hell of a lot more punch than previously.
Well happy.
Living in Gloucestershire, I think I will need to things, an invite to see this car and you take me for a spin[:p], and a toilet afterwards![:O]
LOL, could probably oblige on a couple of those points,... Will need to get the "pampers" option fitted to the seat(s)
Over 400bhp in a FWD car. You nutter [:D] Have you thought about 4x4'ing it?
no.. but 4wd would be quite handy.
Drove mikeT's A3 quattro with IHI a few weeks back.. ~350bhp I think and so easy to drive over their nastiest of roads.. took it all perfectly in its stride. (ibiza would be off road in a tree or ditch driven as hard)
ibiza races next year at castle combe, so can only mod as the rules allow.. (which is'nt much) - I think they might notice it was 4wd but seat never made a 4wd ibiza. (leon yes)
Ah well, but keep us informed as to when the first race is. I'd love to see it in action!
I'll be at combe with the TTOC on 10th Dec..
2006 calendar wont be given to us until jan 06
That car always sounded crazy when I have seen it on the rollers. Can't even imagine what the pace must be like.
How much does that thing weigh?
Great result! Car must be amazing!
I was at jabba the other week and spotted your car a-la bumper missing.
Is this the A3 you mention?
yep, that my naked front ended ibiza. in RR mode.. (does'nt clear the rollers with bumper on)
yep, thats mike A3 quattro IHI.. great bit of kit.
1130kg I think now. and loosing weight and sundries by the day.
Bill, what seats have you got? The standard Seat's or racing buckets? I
only ask as i saw a post on here from someone who has bought some
'Raceland' buckets that have saved him almost 20kg each i beleive.
Bill, what seats have you got? The standard Seat's or racing buckets? I only ask as i saw a post on here from someone who has bought some 'Raceland' buckets that have saved him almost 20kg each i beleive.
Sparco bucket seat(s) currently.
I love it Bill, where can specs and prices be found on these hybrid turbos?
some discussion here>> http://www.seatcupra.net/forums/showthread.php?t=54260&page=4&pp=20&highlight=pe1820
their web addy> http://www.powerenterpriseusa.net/main/turbo/list_spec/index.htm
ripped from that>
"The PE1820 is well-known in performance circles for making BIG power and putting down good numbers. How does 11.68 @ 121 mph in the quarter mile sound? This turbo uses all IHI components custom-specified by Power Engineering of Japan. The center section is a roller bearing design for excellent spool characteristics.
Flow is rated at 630 CFM at 1.0 bar.
Comes with a 0.8-bar wastegate spring. Call for other spring options."
nicked from>> http://www.fastwrx.com/poenpetu.html
first flowrate number I've seen posted on an IHI
and there's more
"Power Enterprise PE 1820 Turbo
The PE 1820 Turbo is a high-performance turbo developed by Power Enterprise. This turbo uses IHI turbine & compressor housings and incorporates PE's custom twin-ball bearing center cartridge. This design allows the turbo to be capable of over 440+ HP (~360+whp). The PE1820 is well suited as a race turbo. This turbo features a P20 turbine housing which is larger than the PE1818's P18 turbine housing. Although the larger housing induces more lag than the PE1818, the true benefits of the PE1820 is the significantly increased power output levels at 21+ PSI range. This turbo is an excellent choice for customers who are seeking a high power turbo race turbo. This turbo is a direct bolt-on for all GC8, GDA, GDB EJ20 turbo engines. "
nicked from>> http://www.incaroption.com.au/Subaru/subeng/PE1820.htm
and Power Enterprise directly...
hows your Japanese?
http://www.power-enterprise.co.jp/m..._spec/index.htm
Good stuff Bill keep up the good work.
P.S. Did Seat not make a wide ended rear wheel drive ibiza, if we start enough rumours you may convince them that it actually exists [:D][:p]
1 - 20 of 37 Posts
