1 - 20 of 22 Posts
Quote: posted by mags on 08/04/2005 20:40:52
Mine come on after 90 ish if in the auto mode.
So they only come on in auto mode?
Quote: posted by Mark V on 08/04/2005 21:38:49
How can you tell the lights are on in daylight?
The dash would light up and the road signs would reflect.
Quote: posted by mags on 08/04/2005 22:53:20
I assume that they only come on in auto mode as I always leave in auto position. I will try with them off tomorrow but would assume that it won't work.
[:D][:D]
[/quote]
But in daylight you cannot tell if the dash lights are on and signs do not reflect!
[?]The road signs depend on the how bright the sunlight is, but you must be blind if you can't see the light on the dash!
Quote: posted by bbdivo on 09/04/2005 16:34:54
In bright sunlight it would be quite difficult to tell if your lights were on, the light from the dash would be very difficult to notice.
because they ahve a blue tinge i find it no problem at all to tell,plus the little red lights above the gear stick that are about a trillion watts are easy to see
1 - 20 of 22 Posts
