1 - 14 of 14 Posts
Hi guys. I've been searching this for a while but can't find much on this that makes sense!
How can I remove the mirror unit, as I would like to vinyl wrap or paint it!
I've managed to get the plastic covers on the bracket off, but then can't see any screws/clips holding it in place.
Thanks in advance
Arun
After you've taken off the covers to the mount the mirror slides off the circular window base.
From what I remember there is a metal spring tab in the middle, although I cannot remember if you need to put a flat blade screwdriver in there just to undo it.
I'm pretty sure you just gently slide it off and that's it.
Take care with the eletrical connector/wires in the middle
No offense shady , but I wouldn't recommend following that one - it looks like he has hooked out the slide clip with a screwdriver!
Not sure why the ball and socket has fallen out of his mirror as well.:
Try this one for the proper procedure:
http://forums.vwvortex.com/showthread.php?2791098-HOWTO-Replacing-rain-sensor-and-autodimming-rearview-mirror&p=33348041&viewfull=1
It simply slides down and the whole thing comes off.
Have just seen this link, reading through it now, thanks
1 - 14 of 14 Posts
